Different sector angles to each components in an Assembly in Ansys Cyclic Symmetry Analysis
Can we use different sector angles for each components of an Assembly in cyclic symmetry analysis? For example, we are providing 36 (1/10th) degrees of sector angle to Component A and 72 (1/5th) degrees to Component B of sector angle in the assembly. If we could achieve the same, how can we extract the results for the full model, as Ansys provides the option of giving number of sectors for Result Interpretation (Solution-Analysis Setting) for complete model? A simplified representation is provided in the figure.
