how do i design three Basic parts given some attachments in solidwork please someone help?
This model is too easy to need any help!
Hello, you can start by defining the 6 by 6 square, which you later extrude by 1.5. You apply the Chamfer on the top and bottom faces and then you proceeding with the cutouts, you can make use of the Hole Wizard feature with SolidWorks and pattern those according to the drawing (the inner ones are a circular pattern) while the others are linear patterns.
From what I can see, this is mostly a training tasks to get used to SolidWorks Hole Wizard functionality, and you were commissioned to design three different parts to practice these features.
Hey Tee,
I attached the part you have shown here.
Check out the feature tree to see how it was modeled.
The middle 4 bolt hole pattern isn't dimensioned so I had to assume it was 2x2.
If you need more help; feel free to message me.
- Adam Pohl
