how to find the deformation formed during load test?
In a rack doing UNIFORM load test for 1.5 ton approximately, I require deformed drawing of the beam;
Hello, in the image I indicate where the option you are looking for is. You can create a deformed solid to use in the drawing environment, or simply view the deformed beam in another menu.
