Designing an IMPELLER using SOLIDWORKS
Beginner-level SOLIDWORKS tutorial aimed at improving your 3D modelling skills to the next level. I tried to simplify the steps while making the workflow as efficient as possible. At the end of this tutorial, you would be able to:
1. Create Points reference
2. Create Splines and Splines on surface
3. Create Revolve surface
4. Create Projections curves along a direction and a workaround to project curves normal to surface
5. Create Loft Surfaces
6. Split a curve using point on curve
Feel free to comment or share my profile and this tutorial link to your circle of influence.
Step 1: Before you start...
1. Your units are set to English. Go to Document Properties -> select IPS for Units.
2. The model orientation is using Z-up views.
3. Surfaces tab is visible.
Step 2: Create a sketch on the YZ plane: Sketch1
1. Create 5 points according to these values:
a. X: -2.00, Y: 0.00
b. X: -1.98, Y: 0.10
c. X: -1.20, Y: 0.70
d. X: -0.20, Y: 1.50
e. X: 0.00, Y: 2.60
2. Create a spline connecting all points above
3. Make sure the spline is horizontally constrained at the last point
4. Create a vertical axis line through the sketch origin
Step 3: Create a revolve surface: Surface-Revolve1
1. Select Revolved Surface from the Surfaces tab
2. Use the Sketch1 to create a revolve surface
3. Enter 360deg as the Direction 1 angle
4. Click OK
Step 4: Create a sketch on the offset plane: Sketch2
1. Create 4 points according to these values:
a. X: -0.20, Y: 0.59
b. X: 0.25, Y: 1.00
c. X: 0.70, Y: 1.80
d. X: 1.25, Y: 2.165
3. Exit sketch
Step 5: Create projected curve on Surface-Revolve1: Curve1
1. Select Project Curve from Curves command
2. Use Sketch2 as item to project
3. Select Surface-Revolve1 as projection face
4. Click OK
Step 6: Create a sketch on the YZ plane: Sketch3
1. Create 3 points according to these values:
a. X: -2.00, Y: 1.30
b. X: -0.50, Y: 1.80
c. X: -0.20, Y: 2.50
3. Create a vertical axis line through the sketch origin
Step 7: Create a revolve surface: Surface-Revolve2
2. Use the Sketch3 to create a revolve surface
4. Click OK
Step 8: Create a normal line to Surface-Revolve2 from start point of Curve1: 3DSketch1
1. Select 3D Sketch
2. Select Line
3. Pick start point of Curve1
4. Make sure the line ends outwards from Surface-Revolve1, passing through Surface-Revolve2
5. Multi-select the line and Surface-Revolve2
6. Set Perpendicular as sketch relation
7. Exit sketch
Step 9: Create a vertical line upwards from end point of Curve1: 3DSketch2
1. Select 3D Sketch
2. Select Line
3. Pick end point of Curve1
4. Make sure the line ends upwards from Surface-Revolve1, passing through Surface-Revolve2
5. Exit sketch
Step 10: Create a loft surface: Surface-Loft1
1. Select Lofted Surface from the Surfaces tab
2. Select 3DSketch1 and 3DSketch2 as the Profiles
3. Select Curve1 as the Guide Curve
4. Click OK
Step 11: Create an intersection curve: 3DSketch3
1. Select 3D Sketch
2. Select Intersection Curve from Convert Entities command
3. Pick Surface-Revolve2 and Surface-Loft1
4. Click OK
5. Exit sketch
Step 12: Create a loft surface: Surface-Loft2
2. Select Curve1 and 3DSketch3 as the Profiles
3. Click OK
Step 13: Create a circular pattern: CirPattern1
1. Select Circular Pattern from the Features tab
2. Uncheck Features and Faces box
3. Check Bodies box
4. Select Surface-Loft2 as Solid/Surface Bodies to Pattern
5. Select circular edge from Surface-Revolve1 as Pattern Axis
6. Enter 10.00deg as Angle
7. Enter 2 as Number of Instances
8. Make sure the circular pattern arrow is pointed upwards (click on Reverse Direction if not)
9. Click OK
Step 14: Create reference point: Point1
1. Select Point from Reference Geometry command
2. Pick inner edge of CirPattern1
3. Enter 1.00 as distance along curve
4. Click OK
Step 15: Create reference point: Point2
2. Pick outer edge of CirPattern1
3. Enter 1.30 as distance along curve
4. Click OK
Step 16: Create spline on surface: 3DSketch4
1. Select 3D Sketch
2. Select Spline on Surface
3. Pick Point1 & Point2
Step 17: Trim surface using 3D Sketch: Surface-Trim1
1. Select Trim Surface from the Surfaces tab
2. Select the lower surface area relative to 3DSketch4 as Pieces to Keep
3. Click OK
Step 18: Create a circular pattern: CirPattern2
3. Check Bodies box
6. Enter 5.00deg as Angle
9. Click OK
Step 19: Create reference point: Point3
2. Pick inner edge of CirPattern2
3. Enter 1.50 as distance along curve
4. Click OK
Step 20: Create reference point: Point4
3. Enter 1.93 as distance along curve
4. Click OK
Step 21: Create spline on surface: 3DSketch5
1. Select 3D Sketch
3. Pick Point3 & Point4
Step 22: Trim surface using 3D Sketch: Surface-Trim2
3. Click OK
Step 23: Create a circular pattern: CirPattern3
3. Check Bodies box
4. Select Surface-Loft2 and Surface-Trim1 as Solid/Surface Bodies to Pattern
6. Enter 360.00deg as Angle
7. Enter 18 as Number of Instances
9. Click OK
Step 24: Create a circular pattern: CirPattern4
3. Check Bodies box
4. Select Surface-Trim2 as Solid/Surface Bodies to Pattern
7. Enter 36 as Number of Instances
9. Click OK
Step 25: Clean-up
Make all the necessary clean-up to make sure only related surfaces are visible.
