How To Create Clipping Path In Photoshop
Clipping path is a popular photo editing techniques . If you want to remove background from image, you must consider image clipping technique.
Today, we will learn, how to do clipping path in photoshop.
Let's start
Step 1: Open Image In Photoshop
First of all you need to open image in photoshop. From the file menu, click open and select image that you want to clipping. After that press ok. Image will be open in photoshop can
Step 2: Zoom Image in Photoshop
For doing clipping path perfectly, you need to zoom image. It is up to you how much zoom you need. Some editors zoom 300% whether some editors zoom 500% of the selected image.
Step 3: Select pen Tool In Photoshop
In the stage, you need to select pen tool from photoshop. You will find it in left side tool panel or simply type "P" shortcut key in your keyboard. Pen tool will be selected automatically.
Step 4: Start Creating Outline
You are almost done. Start creating outline around the object. Select 1 pixel inner of the object while creating path. Join the the beginning part with ending at the last.
That's all
You are now able to create clipping path in photoshop
Resources
Step 2: Zoom In Image
Step 3: Select pen tool in photoshop
Step 4: Start creating outline
