Side Pole Test - High Speed Impact - Explicit Dynamics - ANSYS Workbench
Explicit dynamics is a time integration method used to perform dynamic simulations when speed is important. Explicit dynamics account for quickly changing conditions or discontinuous events, such as free falls, high-speed impacts, and applied loads. Because these “nonlinear dynamics” are integrated into the simulation, explicit dynamics is the preferred choice for simulating highly transient physical phenomena.
Some side impacts involve a vehicle travelling sideways into rigid roadside objects such as trees or poles. Often this is the result of a loss of control on the part of the driver, owing to speeding, misjudgement of a corner or because of a skid in slippery conditions.
Step 1: Overview
Step 2: Setup
- Drag and Drop a Explicit Dynamics Analysis on ANSYS Workbench Main Menu:
Step 3: Engineering Data (Material Model)
- Structural Steel (Default Material Model) has been selected as the material of Rigid Side Pole:
- Non-Linear Aluminum Alloy Material Model has been used to simulate the crashing component as below:
Step 4: Geometry (Design Modeler)
- The 3D Models have been created on internal module of ANSYS Workbench which is named as "DesignModeler":
- The modeling parameters for Rigid Side Pole (Solid Body) could be seen below:
- The modeling parameters for Crashing Component (Surface Body) could be seen below:
Step 5: Body Interactions
- Frictionless Body Interaction has been created between Rigid Side Pole and Crashing Component:
- The "Penalty" Formulation and "Discrete Surface" are considerably important for this tutorial:
Step 6: Meshing Operations (Default Geometry)
- The default mesh operations with the "Linear" Element Order as 4.0mm Element Size have been implemented:
Step 7: Boundary Conditions
- The Initial Conditions without ant Pre-Stress values have been implemented as below figure:
- The velocity has been defined as below:
- The Fixed Support has been implemented in order to simulate the Rigid Side Pole:
Step 8: Analysis Settings
- Solver Options could be seen below:
Step 9: Results
- Total Deformation:
- Equivalent Stress:
- Equivalent Plastic Strain:
